Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through January 29, 2010
Old    Stephen Selby (stephisto47)      Join Date: Dec 2009       12-13-2009, 4:22 PM Reply
Will the Hyperlite Clash fins fit on a 2009 Marek? Has anyone ever tried this for fins at the cable?
Old    Jon D (jdwake1)      Join Date: Sep 2007       12-13-2009, 4:43 PM Reply
Correct me if I'm wrong but marek fins are metal and most cables wont let you hit obstacles with metal fins.....
Old    Nick Tomsyck (sidekicknicholas)      Join Date: Mar 2007       12-13-2009, 4:51 PM Reply
i feel thats why he is asking if the CLASH FINS go onto the MAREK, not the other way around.
Old    Jon D (jdwake1)      Join Date: Sep 2007       12-13-2009, 4:55 PM Reply
haha sorry long day!
Old    Corey James McKenna (coreym)      Join Date: Sep 2008       12-13-2009, 7:40 PM Reply
yes, the Clash fins will fit on the Marek board.
Corey M @ Hyperlite
Old    Stephen Selby (stephisto47)      Join Date: Dec 2009       12-13-2009, 9:17 PM Reply
Thanks Corey. I also have one more quick question for you. How would the 2010 Team boots fit on a 2009 Marek? Would the stance options be at all limited?
Old    Tom Pazerunas (tom_paz)      Join Date: Jan 2003       12-13-2009, 9:36 PM Reply
you can fit the 2010 boots with the standard '10 baseplate but will limit the widest stance for the 8" hole pattern, basically by an inch or two. To get the widest stance possible, i'm pretty sure you can use an 09 baseplate that will fit equally well on the '10 boots. ask your local shop if they have any spare 09 plates, they should be able to swap you out.
Old    Geoff Fagien (gfagien)      Join Date: Jun 2009       12-13-2009, 10:13 PM Reply
you can use the 09 base plates on them, but you can also use the new base plates, if you set them all the way out it looks like the boot is uneven or one insert in, but the boot is in the same place. They showed me that at miami ski nautique. Also the clash fins work great on the marek i used them on it last time i hit up owc
