I haven't found any contact info on the Hydrodyne site and the e-mail link didn't work when I tried it. The site hasn't been updated since 2002.
Ok....pics
As you can see, no windshidld and no upholstery.
For ballast, I'm gonna turn the bench seat (last pic) into a tank, it should be around 400lb, slide two of those long narrow launch pad bags under the floor between the stringerss aft. I hadn't figured out how much weight to put in the bow yet, but 450 sounds like a good place to start. I'm using a two pump system, one in one out for simplicity and the same through hull (which already exists). The two bags under the floor are on their own circuit and there is a circuit for the bench, bow and a spare incase I decide to add another bag somewhere. Switching feeds into the pumps is done with a flow-rite three way valve and the circuits are isolated with plastic gate valves and the vents all have check valves. I'll try to post a sketch of the system so everyone can point out the problems later.
For the interior the upholstery will end up looking pretty stock, but no carpet on the floor, just nautolex flooring and the hull sides are gonna have either carpet or a foam backed vinyl, we'll see.
The next step is to get the ballast system plumbed in, do some more cleanup and gelcoat the port console. Then I can get going on the the upholstery and floor. I'm hoping in the mean time to pick up a tower and figure out a basic stereo as a base of something bigger in the future.
It would be great to find a windshield though, as I've said thats been the biggest hurdle so far. I can always go without one, but I'd rather not.
