Old     (edge04)      Join Date: Mar 2010       06-07-2013, 2:22 PM Reply
I need to replace my flexiable heater hoses and looking to see if there is something better as these rip easy. Was thinking maybe the hose RV's use to empty the crapper with? Anyone know of a good replacement?
Old     (srock)      Join Date: Mar 2002       06-08-2013, 6:50 AM Reply
That sounds like a real problem if your loosing them that easily. Are you getting vibrations at the fitting?
Old     (edge04)      Join Date: Mar 2010       06-08-2013, 7:45 AM Reply
I am talking about the flex plastic tubing that th hot aire blows through. The vents.
Old     (srock)      Join Date: Mar 2002       06-08-2013, 7:57 PM Reply
I've been around boating a long time and that's a damn good question. I have seen the problem with vent hose as well particularly with age. I don't have a good solution other than applying a little foil tape at stress or high damage areas.
Old     (Pad1Tai)      Join Date: Jan 2013       06-09-2013, 7:17 AM Reply
The flex hoses that come with the kit, I think their called defroster hose, lose a lot of the heat by the time they get to the vent fitting... I believe it's a 3 inch hose.. Maybe some insulated flex hose would work,,
Old     (edge04)      Join Date: Mar 2010       06-10-2013, 12:22 PM Reply
maybe something like this:
http://www.dwincorp.com/products/30/...se-50-ft-piece
