Old     (burn229)      Join Date: Nov 2007       05-09-2011, 8:11 AM Reply
Need to replace my strut on my 07 sanger v215 becuase its bent. Has anyone done this before? What size/type should I replace it with?
Old     (bcrider)      Join Date: Apr 2006       05-09-2011, 9:01 AM Reply
I bent mine on my DD a few years back. Wasn't that hard to replace. Just had the dealer that I bought my boat from to order me a new strut. There are some markings on the strut but not much. I would either contact Sanger dealer or sanger themselves for the proper one. Dealer guy lent me his shaft puller and removed everything myself. Biggest thing when you bend a strut is to make sure the drive shaft is still straight and hopefully it is as this can be a spendy piece to replace on top of a already bent strut. When replacing the strut put some marine silicon around the base and each bolt going through the hull to keep watertight.
Old     (h20king)      Join Date: Dec 2009       05-09-2011, 3:40 PM Reply
you can get everything you need to do the job from these guys its not a hard job........................H
http://elberts.com/underwatergear.htm
Old     (kko13)      Join Date: Jul 2006       05-09-2011, 5:07 PM Reply
You just need to make sure you have the right shaft diameter and degree of strut.those are the 2 things that need to be the same as the one you took off.
I just did my 03 Tige for example1 1/8" shaft with a 16 degree angle.Not sure what your boat would be ..but thats what you need to know.Good Luck.
You need to take a look at the shaft to make sure its straight. I didnt even know mine was bent until i started taking on water because the strut being bent pushed my shaft over about 3/4" where it comes through the boat and it wore my shaft seal and caused a leak.So take a look at that too and make sure it didnt get damaged.
I got lucky and the shaft was not bent just pushed over..but you do need to make sure its not bent.
