Old     (cool232)      Join Date: Jan 2006       03-07-2007, 6:23 AM Reply
Does anyone have suggestion on how to make some or where to buy them.
Old     (hawaiianstiln)      Join Date: Oct 2004       03-07-2007, 7:25 AM Reply
Easy... I will take a photo of mine tonight and post it on here.
Inside the passenger cave of my VLX, I took measurements of the wall that lines the outside hull (inside left). Cut the particle board to fit and then painted 3 layers of "herculiner" all over it. You can buy herculiner at Autozone. It's basically a roll on bed liner that seals like a Tank! Or you can just roll on Fiberglass resign if you want.. Either way..
I positioned all the amps how I wanted them and then drilled holes for the wires. Mounted the amps and pre-wired everything on the board before I put it back in the boat. The Amp rack was obviously heavy and needed help, but it looks great!
Old     (hawaiianstiln)      Join Date: Oct 2004       03-08-2007, 8:31 AM Reply
forgot..
UploadUpload
Old     (rbc_racing)      Join Date: Jan 2007       03-11-2007, 6:50 PM Reply
great looking setup keith, But how did you attach the amp rack to the boat?
(Message edited by rbc_racing on March 11, 2007)
Old     (hawaiianstiln)      Join Date: Oct 2004       03-11-2007, 9:51 PM Reply
as it lays against the side of the boat at an angle, I just bought to aluminum L brackets at Lowes and painted them to match. I attached one L bracket to the top right and another to the bottom left.
Old     (mikeski)      Join Date: Aug 2003       03-11-2007, 10:16 PM Reply
After experiencing a few heat issues with amplifiers in friend's boats I now try to run amps to the cooling fins are vertical instead of horizontal as shown in the picture above. In most cases the graphics will look better when installed but they will perform better if turned sideways.
My amps are mounted on 1" x 1/4" aluminum bars with space above and below for air circulation. Sorry I don't have any pix handy.
Old     (hawaiianstiln)      Join Date: Oct 2004       03-13-2007, 7:18 AM Reply
I run my amps at 2 ohms when it's 116 degrees outside and don't have any problems. I have only had them cut off once when parked for 5 hours and playing it as loud as it can for the entire time.
Old     (cprfab)      Join Date: Dec 2006       03-14-2007, 10:45 PM Reply
Old     (mikeski)      Join Date: Aug 2003       03-14-2007, 11:07 PM Reply
Gunnar,
I like that setup, great design so the heat floats off the amps, looks great too.
Old     (cprfab)      Join Date: Dec 2006       03-15-2007, 9:20 AM Reply
Thanks Mikesi
Old     (rukie)      Join Date: Jan 2006       03-15-2007, 10:27 AM Reply
Start hi-jack
Gunnar-Agree w/Mikeski, looks killerDon't stop w/ amp racks, let's see the rest
End hi-jack
Old     (hawaiianstiln)      Join Date: Oct 2004       03-15-2007, 11:17 AM Reply
NICE!!!
Old     (cprfab)      Join Date: Dec 2006       03-15-2007, 2:09 PM Reply
Boat is tore apart I'll get some pics up when its back together. The other pics I have suck
Old     (audiopro74)      Join Date: Jun 2005       03-15-2007, 7:15 PM Reply
Gunnar,
What material did you use. Are they showing any signs of fatigue on the welds. Love the look, I am just use to "customer-proofing" installs, and that seems like after a few drunken super triple double ups the weight and angle might crack the welds. It does look sick though...
Old     (cprfab)      Join Date: Dec 2006       03-15-2007, 7:56 PM Reply
Welds are not a problem. I would be more concerned if it was alum. but it's 3/16 steel and I laid some weld on both sides of the angle iron.
Old     (aquahawk)      Join Date: Feb 2005       03-23-2007, 11:22 PM Reply
Nice to get some ideas for my bu...
Old     (clubmyke)      Join Date: Aug 2004       03-24-2007, 7:20 AM Reply
gunnar - that is one cool install !!! who made up the brackets ?
Old     (cprfab)      Join Date: Dec 2006       03-24-2007, 9:25 AM Reply
did the entire install myself
Old     (clubmyke)      Join Date: Aug 2004       03-24-2007, 9:34 AM Reply
any interest in selling some side brackets for zapco amps ? or at least some pics ?
that is the nicest amp install i have seen to date..
(Message edited by clubmyke on March 24, 2007)
Old     (aquahawk)      Join Date: Feb 2005       03-24-2007, 10:04 AM Reply
A little measurin', a little patience and a little $ and you can do them yourself. I am designing some myself along with some laser etched lexan with the bu logo for my speaker box. once I get them I will share. here's the site.
www.Emachineshop.com
Old     (rosh)      Join Date: Sep 2005       03-26-2007, 1:51 PM Reply
Do you conect the negative of the amps to the battery or do you ground it on the boat, and if you do that where do you ground it?
Thanks
Old     (mendo247)      Join Date: Mar 2005       03-27-2007, 8:16 AM Reply
wow! very clean and simple...
Old     (loudsubz)      Join Date: Aug 2001       03-29-2007, 6:43 PM Reply
all grounds go back to the same place...the NEG of the battery.
Its a better idea to run it right back to the battery as you dont know what the return gauge is of the OEM wire on the ground system. Since electrons move negative to positive you would be limiting yourself if you have a heavy current draw as well.
Old     (jroo_the_damager)      Join Date: Feb 2007       03-29-2007, 11:41 PM Reply
Need help choosing amps to run (1) pair Pro-80x, (1) 10 or 12w7, and 6 polks inside boat my 07' Malibu VTX. I want clear sound but want to be good with storage space. I also want to consider options that won't load the batteries too bad when floating. Should I consider alternator improvements? Thanks for any advise!
Old     (hawaiianstiln)      Join Date: Oct 2004       03-30-2007, 2:53 PM Reply
Josh, you should probably start a new thread and you might get your questions answered. This thread deals with amp racks. :-)
