Old     (surfdad)      Join Date: Sep 2004       09-16-2007, 6:04 AM Reply
This is to test your specific knowledge of wakesurfing and/or sense of humor. :-) Feel free to add your own questions with pictoral references, please.
The first two are on board selection.
When selecting a board, one that is large enough (length, width AND thickness) such that you cannot sink the rails is:
a) Just right
b) Too large
c) Too cold
d) Like a pelican it's bill can hold more than it's belly can
Old     (surfdad)      Join Date: Sep 2004       09-16-2007, 6:07 AM Reply
When selecting a board, the spray originating from the inside rail should reach your waist.
a) True
b) False
c) Did you the size of those feet?
Old     (surfdad)      Join Date: Sep 2004       09-16-2007, 6:13 AM Reply
The next question tests your knowledge of board orientation.
When riding backside, your...backside should be:
a) pointed away from the boat
b) pointed toward the boat
c) close to your head, who rides backside?
d) pointed at the wake.
Old     (dennish)      Join Date: May 2005       09-16-2007, 7:21 AM Reply
The correct answer is all of the above
right?
Old     (dennish)      Join Date: May 2005       09-16-2007, 7:45 AM Reply
The answer to the backside question is. pointed at the distant horizon because you are to high above the wake.
Old     (dennish)      Join Date: May 2005       09-16-2007, 8:08 AM Reply
#4
Using your head while wakesurfing means?
a) always use a pfd
b) never surf behind an outboard
c) ride with your head in the water
d) all of the aboveUpload
