Old     (monkey)      Join Date: Oct 2002       09-03-2007, 2:08 PM Reply
Kind of an open ended question... Which of these boats can produce the best wakesurfing wake?
> Sanger V210
> Moomba Outback V (was called the Mobius LSV in '05??)
> Malibu V-Ride (same hull as the 2004 and older VLX??)
> Nautique Crossover SV-211
> Centurion, Storm Series, Cyclone C4
> Mastercraft X1, X2, or X7
> Tige 20V
Old     (melanie)      Join Date: Apr 2001       09-03-2007, 3:18 PM Reply
> 247
Old     (monkey)      Join Date: Oct 2002       09-03-2007, 3:38 PM Reply
too big for my riding spot.
Old     (bigshow)      Join Date: Feb 2005       09-03-2007, 7:05 PM Reply
Look for something with high gunnels so you can load it up. Ya, a 247 is a little big, whatís your size limit?
Iím going to ride behind an X1 the first weekend in October. I rode behind it this spring but the boat wasnít ballasted as much as it is now. I need a little more wake than when I rode behind it last time.
Iíve ridden behind an older Malibu I forget the model. The owner said it was then same hull as the original Wakesetter. The boat was a d-drive. Properly weighted the wake was pretty good.
Iím kind of a Centurion guy but I donít have much experience with anything but my boat and an Avalanche. The Cyclone is supposed to be a scalled down Avalanche. The Avalanche surf wake is really amazing. The new 21í6Ē Lightning should be pretty good, but that might be over the limit.
Old     (smedman)      Join Date: Feb 2006       09-03-2007, 7:08 PM Reply
Hey Tim,
I can't speak for the other boats, but I get a decent wake on the V-Ride. Not 247 big for sure, but fun. I'm not blasting huge airs like James, Chase, and Drew :-) , but getting the fins out of the water on occasion...
See the vid to check the wake. http://www.youtube.com/watch?v=iGOLYQb-JKU
Old     (norris_laker)      Join Date: Aug 2006       09-03-2007, 7:49 PM Reply
Tim,
A friend of mine has a 21 ft VLX Wakesetter. He gets a good goofy wake but a weak port side wake. From what I've read on the net, you need about 2500 lbs of ballast to get a good port side wake. I have the X-1 (actually a 2005 X-2) that Ed was talking about. We probably run around 1300 lbs of ballast and get a very good port side wake. We surf anywhere between 9.5 to 13.5 miles per hour. The starboard side is a different story. We can only get a decent wake at 10.5 miles an hour. I love our 2005 X-2 but if I was a goofy rider, I wouldn't recommend the X-1 hull. A picture of our wake can be found at http://www.wakeworld.com/MB/Discus/messages/87668/470540.html?1185544672. I agree with Ed about the Avalanche. Great goofy and regular wake. The rear walk through also make a great storage area for your quiver of boards.
Old     (bigshow)      Join Date: Feb 2005       09-03-2007, 8:05 PM Reply
Ya, that's Roy's boat.
Roy, I'm copying your videos from Nationals right now. I do think that both the Avalanche regular and goofy wakes are quite good. However as you can expect the Port wake looked a little better to my eye. After riding behind that Avalanche wake David says the Avy Starboard is much better than my boat, better even when I have 2,500 pounds of ballast.
Isn't the VLX is 21'6"?
Old     (monkey)      Join Date: Oct 2002       09-04-2007, 7:43 AM Reply
Thanks for the input everyone.
21 foot is the limit at our lagoon. Anything longer and they won't let you ride.
I'll be buying something new this winter.
Old     (tonyv420)      Join Date: Jul 2007       09-04-2007, 1:55 PM Reply
CENTURION C-4 BEATS ALL OUT THERE!
Old     (tonyv420)      Join Date: Jul 2007       09-04-2007, 1:56 PM Reply
Sorry, the avalanche C-4, or the enzo throws the best wave hands down.
Old    4sher            09-04-2007, 4:51 PM Reply
Too bad you can't go to 21' 6" because the Enzo 216 throws a GREAT surf wake. The Inland Surfer crew rode behind one at the Lake Tulloch contest and we all liked it.
Old     (clubmyke)      Join Date: Aug 2004       09-04-2007, 5:24 PM Reply
nautie 211 for goofy...
Old     (wakeslife)      Join Date: Jul 2005       09-04-2007, 6:13 PM Reply
The X1 will throw a very nice port wake with not much weight over stock. I actually prefer it to a 07 VLX setup with similar weight.
Old     (malibu)      Join Date: Sep 2004       09-10-2007, 11:30 AM Reply
I surf behind a Sanger V210. It doesn't take as much weight as the bigger boats to get a nice wave. We met a guy Labor Day weekend with a Calabria V drive that was really impressed with our wake.
Old     (rwb)      Join Date: Aug 2005       09-10-2007, 11:38 AM Reply
I will say the V-Ride will give you the best of all worlds. Great wakeboarding wake and a good surfing wake.
Old     (jpk)      Join Date: Sep 2005       09-10-2007, 3:57 PM Reply
My V-ride wake looks pretty similar to Smedman's video above. I find the wake is a lot taller and cleaner with the wedge down. Some folks say the wedge ruins a surf wake, but after many days trying to get the wake dialed in with just ballast and speed adjustments, I never got anything right until the wedge came down. The wake is similar on either side of the boat, not as finicky about sides as the MC X-1.
Old     (rio_sanger)      Join Date: Apr 2007       09-10-2007, 6:05 PM Reply
Our V-210 works great, and not much different from port to starboard.
