Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through August 19, 2008
Old     (oaf)      Join Date: Jul 2002       07-19-2008, 12:28 AM Reply
OK I just finished my first day of installing an Auto Ballast system. I have a blog if you are interested in seeing some of the pics and details that went into it. Not a very hard project just nerve racking drilling holes into your boat.
http://tige-ballast-install.blogspot.com/
Old     (loudsubz)      Join Date: Aug 2001       07-19-2008, 7:15 AM Reply
Looks good
Did the Tige not come with any ballast from the factory?
Old     (scottnaz)      Join Date: Feb 2008       07-19-2008, 7:16 AM Reply
Looking good Coach
Great looking Tige
Old     (oaf)      Join Date: Jul 2002       07-19-2008, 8:15 AM Reply
Matt- No it did not come with Factory Ballast. It is the running debate (really joke) that Tige's don't need ballast. A large number of guys at Tigeowners have all done their own systems now.
Old     (tanner)      Join Date: Oct 2005       07-19-2008, 8:59 AM Reply
In the past the factory ballast has been kind of a joke, as it was hard tanks and you lost all your space. Hence the reason most the guys choose to do their own ballast.
BUT that being said, Tige's ballast system this year is finally under floor, and looks promising.
Old     (bjeremi)      Join Date: Mar 2006       07-19-2008, 2:40 PM Reply
Why the two types of hoses? One for supply/drain and one for venting?
Old     (oaf)      Join Date: Jul 2002       07-20-2008, 7:34 AM Reply
Brenner. The Multiflex was not recommenced for drain under the water line so I used the flex PVC just to be safe.
Old     (oaf)      Join Date: Jul 2002       07-20-2008, 5:28 PM Reply
I just updated the blog with the finished product! Did a lake test today and it was money. No leaks and the wake was huge!
Old     (nyelland)      Join Date: Oct 2005       07-23-2008, 3:20 PM Reply
Getting ready to do the same on my boat. Did you use any kind of sealant / epoxy on the thru-hull water intaks below the water line?
Old     (oaf)      Join Date: Jul 2002       07-23-2008, 4:33 PM Reply
Neil-
YES!!!!! I used 3M 5200 Fast Cure in White on all of the though hulls. It is not necessary on the though hulls above the water line but figured I had enough to spare. I gooped a ton of it on the scoop on the outside and put a bead on the threads on the inside tightened the nut and then gooped a ton more around the whole assembly on the inside of the boat. I found the 3M 5200 at Home Depot in the paint depart for about $7. If you need to get a deal on Fly High bags and Jabsco pumps let me know and I will send you the number and e-mail of the guy who set me up with the base parts.
Old     (nyelland)      Join Date: Oct 2005       07-23-2008, 10:51 PM Reply
Coach-
Thanks. I have the fly high sacks. The pumps, thru-hull, hose, and switches are comming soon. My boat (Centurion) is all-ready pre wired for the rear ballast on either side. They have one wire harrness for the boat so adding accessories is easy for the dealer to do on a boat on the lot.
Any tips on drilling holes through the hull?
Old     (oaf)      Join Date: Jul 2002       07-23-2008, 11:55 PM Reply
Neil-
Pre drill the holes using a scrap piece of wood and make sure you have a tight fit with your hole, if not buy a smaller hole saw. Once you have your mark I put blue painters tape over the gel. Once the hole saw got close to the surface I reversed the drill until I was through the gel coat then put the drill back forward and finished my way though. Drill from the outside in and in reverse so you don't crack the gel.
Old     (boomshot)      Join Date: Jan 2008       07-24-2008, 8:03 AM Reply
Is this photo before or after the ballast was full?
Old     (oaf)      Join Date: Jul 2002       07-24-2008, 8:07 AM Reply
Truth-
This is after the rear was about 3/4 full and the front was full. I found some sharp screws that I have to change out under the seat base so I couldn't fill the sacs up all of the way. I didn't get any very good photos of the wake. I am going to Lake San Antonio, CA for a week and will have some time to dial in the wake.
I think I will do some before and after shots which will be good for comparison purposes.
