Old     (jaegermaster)      Join Date: Sep 2002       10-02-2010, 6:44 AM Reply
I am trying to find the radius of this piece I need to cut out of a 24" glu lam beam. Can anyone help? Is there even enough info to get the radius? I hope my crappy drawing is decipherable.
Thanks for any help.
Old     (jaegermaster)      Join Date: Sep 2002       10-02-2010, 7:11 AM Reply
If the drawing doesn't make sense, I have a 24"X109" beam. I need to cut a 10 1/2" wide radius out of it.
Thanks for any kind of response.
Old     (pwrvelocity)      Join Date: Jan 2007       10-02-2010, 10:38 AM Reply
D = 2r
D = Diameter
r = radius
2 (10.5") = 21"
Old     (bdavis)      Join Date: Sep 2002       10-02-2010, 10:50 AM Reply
I'm pretty sure that's wrong w. I don't have a formula. But I would lay the beam on the ground. Have another person hold the end of a string and move far enough away until you can achieve the arc you want. The length of th string is your radius
Old     (pwrvelocity)      Join Date: Jan 2007       10-02-2010, 11:02 AM Reply
Pretty sure I'm wrong????? Look it up in your Geometry book, Einstein!
Old     (sidekicknicholas)      Join Date: Mar 2007       10-02-2010, 11:30 AM Reply
From that picture 10.5" is only a piece of the radius..... just the portion of the radius of 109" of the circle.... the radius in fact would be much much larger.
On the drawing - are you cutting out a 10.5" wide piece (e.i. - 2 cuts -top and bottom)? or just one cut 10.5" from the base of the board?
@ W - 1st post he is looking for the radius, so you have a equation - that is no help. good job.
Old     (hunter660)      Join Date: Aug 2007       10-02-2010, 12:56 PM Reply
Outside = 157.1905"
Inside = 146.6905"
Old     (diamonddad)      Join Date: Mar 2010       10-02-2010, 1:08 PM Reply
You could calcute it from the 3 point math...
http://local.wasp.uwa.edu.au/~pbourk...y/circlefrom3/
Old     (jaegermaster)      Join Date: Sep 2002       10-02-2010, 1:31 PM Reply
I need to make both the top and bottom cuts.
Old     (jaegermaster)      Join Date: Sep 2002       10-02-2010, 1:53 PM Reply
I found this equation which apparently will give me the radius, but I'm not sure how the math works.
http://mathforum.org/library/drmath/view/69144.html
Old     (john211)      Join Date: Aug 2008       10-02-2010, 2:23 PM Reply
inside r = [(109 / 2) **2 + 10.5 **2 ] / 2 * 10.5 = 146.69
outside r = 146.69 + 10.5 = 157.19
Old     (jaegermaster)      Join Date: Sep 2002       10-02-2010, 3:32 PM Reply
Thanks everybody. I'll let you know how it turns out.
Old     (jaegermaster)      Join Date: Sep 2002       10-04-2010, 5:24 PM Reply
Here is the final outcome. Thank you all for your help. I really appreciate it.
Before, during and complete.
Old     (bigdad)      Join Date: Apr 2002       10-05-2010, 7:18 AM Reply
Did someone call the cops on you?
Old     (mattgettel)      Join Date: Jan 2009       10-05-2010, 8:00 AM Reply
They must have heard you had doughnuts.
Old     (jaegermaster)      Join Date: Sep 2002       10-05-2010, 8:28 AM Reply
No, I have a Sheriff's Deputy that lives across the street. I do think I piss him off sometimes when I am working in the garage and he is on night shift. Oh well.
Old    bigdtx            10-05-2010, 10:25 AM Reply
So what's it going to be?
Old    bigdtx            10-05-2010, 1:27 PM Reply
And what did you use to make the cut? That's a pretty mondo cut regardless of the tool.
Old     (jaegermaster)      Join Date: Sep 2002       10-05-2010, 6:37 PM Reply
It's going in between two entry columns on a custom home. I cut it for a local builder.
I made a template out of 1/2" ACX plywood and used a 2hp plunge router with a collar. I took about 1/8" of depth per pass. The sketchy part was I could only rout 2 1/2" deep and then I had to flip it and get the template lined up exactly to rout the other side.
