I believe you meant 500 lb sacks... I think you are going to be happy. The Wedge really makes the wake much harder and a little steeper and a little bigger, overall all good things. If you have been running just weight on the sides of the engine compartment then you were probably getting a decent wake, it was probably really rampy and smooth. The weight and wedge will be a good improvement. I am not familiar with the fluid conceps system, but I would like to suggest that I don't think you are going to fit 1000 lbs of water in your ski locker alone. The factory MLS system in all of the Malibus are only 400 lbs in the ski locker and they are using a bag that is capable of 600 lbs. The problem is the space you have, not enought to let the bag expand fully. You will like the autofill system because you will not have to do any work, but I would question the reality of getting 1000 lbs in your ski locker. Consider having them put two extra bags up under the front seats, that should give you an additional few hundred pounds. Or add some lead bars under seats around the boat. Remember this, the wedge will pull the back of the boat down, so you want to add more weight to the front of the boat. If you were to add all of your weight to the back of the boat you would cancel the effect of the wedge because it would not have much of and angle any more, so add more weight to the front and you will get the enitre boat to sit lower in the water while driving and the overall best wake. Hope this helps...
