04-27-2008, 5:18 PM
Do you use when putting in a Perko? Also I just ground the new battery to the old battery correct?
04-27-2008, 5:31 PM
double 0 guage is usually best
04-27-2008, 5:32 PM
min of 4 guage though
04-27-2008, 5:37 PM
Trey when is the last time you saw 0/2 guage wire for batteries? (Message edited by 05mobiuslsv on April 27, 2008)
04-27-2008, 5:40 PM
Depends on amp (current) load and length of run. Bigger is always better. Grounding to either the original battery or the engine block is ok, which ever is shortest.
04-27-2008, 5:42 PM
And overkill is a waste of money.
04-27-2008, 5:43 PM
Nu bu Most boats come with 2/0 guage
04-27-2008, 5:44 PM
^^^ so is burning your boat to the water line
04-27-2008, 5:44 PM
I meant 0/2 guage. (Message edited by 05mobiuslsv on April 27, 2008)
04-27-2008, 5:47 PM
i used 4g on my isolator setup
04-27-2008, 5:54 PM
Aren't 2/0, 0/2 and double 0 the same thing?
04-27-2008, 6:43 PM
om confused you saying 2 AWG or 00 AWG
04-27-2008, 7:12 PM
Mike I think you're right, I'll go back to my original statement and say CHAS show me an inboard wakeboard boat that comes with 2/0 wiring. Mine came with 2 AWG.
04-27-2008, 7:21 PM
Jay it's 00 AWG this little discussion is about and way overkill for your situation.
04-27-2008, 11:26 PM
Yes, what I ment also. Boats come with 2 AWG
04-28-2008, 10:00 AM
Nu Bu and Chas my 2007 Supra Launch 21V has 2/0 AWG for the main power and ground from the factory. Jay I would run the same size wire out of the perko that is going into it, at least to the main battery. Probably would run 4 AWG to your stereo battery.
04-28-2008, 12:00 PM
N Adams I really doubt that, do you have any idea how big that is? You sure you don't have 2 AWG?
04-28-2008, 12:55 PM
When the wire clearly stats 2/0 AWG and not 2 AWG i am pretty sure. And yes i do know how big that wire is. Do you?
04-28-2008, 2:27 PM
I do just don't believe it came from Skiers choice like that.
04-28-2008, 3:05 PM
Are we still talking about wires here? To me anything over 4 AWG would be more than the job needs which isn't a bad thing if you like spending more than you have too. But heck with how cheap copper is these days why not go for the bigger run.
04-28-2008, 3:16 PM
#2 awg for short runs (<8') to the starter. If you are running 10+ feet of cable to an amplifier distribution block you want to use 1/0 (aka 0) or 2/0 (aka 00) to minimize voltage drop.
04-28-2008, 3:42 PM
Mike he's talking about the run from the alternator and ground from the engine block being 2/0 guage.
04-28-2008, 5:59 PM
Ok that's it I have to go out to the boat and check what I've got again coming from the engine, no way Tige or Supra would do it and not Malibu . I know the wire between the dual batteries is 2awg. (Message edited by 05mobiuslsv on April 28, 2008)
04-28-2008, 6:08 PM
Dang, just realized my pic didn't post
04-28-2008, 7:04 PM
Looks like I've officially been owned on this one, and it's 1/0 awg in my 06' .
