Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through June 21, 2006
Old     (cinder1995)      Join Date: Aug 2002       05-18-2006, 6:45 PM Reply
I have two Mako board racks and I need one of these for each. Any suggestions?Upload
Old     (acurtis_ttu)      Join Date: May 2004       05-18-2006, 7:32 PM Reply
where on the rack is that part from?
Old     (s4inor)      Join Date: Mar 2002       05-19-2006, 7:40 AM Reply
Realistically your best bet is to have replacements fabricated at a machine shop. Unless you're able to find someone that has spare racks lying around to canabalize parts from (I don't have any), it's going to be tough to find a replacement.
Jason
www.wakeside.com
Old     (superairdawg)      Join Date: May 2003       05-19-2006, 4:49 PM Reply
I'd be curious to know where that piece came from too. Monster's racks are extremely similar to Mako's and their customer service killz. You might want to check with them.
Old     (cvnrides)      Join Date: Feb 2006       05-19-2006, 5:12 PM Reply
That looks like the mounting stud that goes on the tower. I have a set that came with my boat (2002 Launch SS). Send me a P.M. if you want them and we can work out a deal.
Vince
Old     (mujibur)      Join Date: May 2002       05-19-2006, 6:43 PM Reply
You may want to check out Ace Hardware. They have some round stock and plate stock Aluminum and if make a mount out of these parts for rather low cost. Buy the proper diameter then cut the cylinder to the proper length, then drill and tap 2 or 3 holes in one end. At that point you can bolt a piece of plate stock to the cylinder, countersink drill the holes to both mount the plate to the cylinder and to mount the plate to the boat ( that mount fit the flat side of the Supra oval towers.). If you are mounting the rack to a round bar - you would have to get more inventive. Maybe buy a monster tower clamp, take out their stainless insert and put another piece in that is round instead of the 4 sided it ships with.}
Old     (cinder1995)      Join Date: Aug 2002       05-19-2006, 7:07 PM Reply
Vince-
You're right, it's the stud that bolts to the tower. I sent you a p.m.
Jason-
I do have acces to a laith and I have the aluminum stock. It was my next step if I couldn't find the parts.
Thanks for the input
Old    chadj99            06-09-2006, 3:16 PM Reply
If you guys can help... I have a MAKO rack and the little black handle broke.... the one that holds the rack the the mount...
here the heck can I find that part?
If I have to I'll buy another whole rack.. But with MAKO out of business.. no one seems to have any......
Old     (acurtis_ttu)      Join Date: May 2004       06-12-2006, 7:21 AM Reply
this looks very similar to the handle, I lucked out and a (surfside dan) had one layign around his shop, btu they are nearly impossible to find.
http://www.rogancorp.com/products.asp?id=190
Old    chadj99            06-14-2006, 7:01 AM Reply
Thanks Adam...
I e-mailed the company, so we'll see what happens...
