Old     (wakemaker01)      Join Date: Mar 2009       02-21-2010, 11:26 AM Reply
What rms watts are yall running to make the pro 80s scream last summer i had 130-150 watts to them thay sounded good but i belive thay can handel a lot more.At 12.5 volts most amps do not make ratted power. So would a alpine pdx 150x4 bridged to two chan be to much that would be 300 watts per speaker. But at 12.5 volts it should be less because the 300 w would be at 14 volts?Is this thinking correct?
Old     (wakemaker01)      Join Date: Mar 2009       02-21-2010, 1:27 PM Reply
Old     (worththewake)      Join Date: Nov 2006       02-21-2010, 1:58 PM Reply
syn 2 powering for Pro 80's no problem....
chris
Old     (worththewake)      Join Date: Nov 2006       02-21-2010, 1:59 PM Reply
correction...four
Old     (chpthril)      Join Date: Oct 2007       02-21-2010, 2:23 PM Reply
I've heard some peeps running a pair bridged on the Syn4! I've had a set running with 325 watts for about 2 years now.
Old     (jonyb)      Join Date: Nov 2008       02-21-2010, 4:24 PM Reply
Syn2 or Syn4. With the Syn4, you have the ability to add another set in the future and still have enough power.
Old     (stevev210)      Join Date: Feb 2005       02-21-2010, 4:41 PM Reply
I have a pair of 80's and a pair of 60's being pushed by the syn2. 175 watts each and they scream.
Old     (talltigeguy)      Join Date: Sep 2003       02-21-2010, 5:34 PM Reply
I have heard Tim White himself say that they can handle more than the 200 Watts RMS. Important that they are tuned properly, but he also gives great advice on that.
I would contact Wetsounds so that you aren't getting advice from a bunch of nutheads on WW who aren't going to be responsible if things go bad. They always give good advice on this sort of thing.
Old     (justsan)      Join Date: May 2009       02-21-2010, 8:10 PM Reply
I have my pair of Pro80's running off a PDX150.4 bridged to 2 channels -wouldn't have it any other way, sounds amazing.
Old     (carter13)      Join Date: Feb 2009       02-21-2010, 9:01 PM Reply
I have a pair of 80's powered by a Syn2 and they crank.
Old     (silvermustang35)      Join Date: Jul 2008       02-22-2010, 5:06 AM Reply
Syn2 with a pair of Pro80s cant go wrong, they are a perfect match...
Old     (spencerwm)      Join Date: Feb 2009       02-22-2010, 10:34 AM Reply
I ran them with a Tru Technology t2.100 amp and they rocked. Go high end on your amp and you will be happy. The cleaner the power the better.
Old     (factorykitted)      Join Date: Jul 2009       02-22-2010, 10:55 AM Reply
I run two Wet Sounds SYN4 - bridged to four Pro 80's
