Old     (boarditup)      Join Date: Jan 2004       06-01-2005, 8:45 AM Reply
It is the time of the year where things get going. If you swap out your prop, check your prop nut after the first few uses. The nylon bushing does wear out and may back off with the vibration of running. Personally, I use a new nut every other prop change. I also check it every once and a while to make sure it is fully seated. I have sold a few props to replace those that have fallen off the boat after hitting reverse.
