Old    dsullivan            08-25-2003, 12:39 PM Reply
I am considering a 95 or newer nautique but am finding only boats with high hours are affordable, at almost 800 hours. What should I do and how can I determine if the engine has been taken care of and will not require a major overhaul or major repairs in the near future ?
Old     (rock_n_boardin)      Join Date: May 2003       08-25-2003, 1:01 PM Reply
Ask for service receipts, if they did the work themselves you might not get any. But if they didn't, then they might not have had it maintained properly, and if they did that is a good sign.
Old    tommyadrian5            08-25-2003, 1:16 PM Reply
have a mechanic survey it, check compression, etc, you can have oil analysis done to it but i'd only do that if you were sure you were buying it barring major issues.
Old     (troyl)      Join Date: Feb 2002       08-25-2003, 3:48 PM Reply
If the engine and trans oil was changed regularly then 800 hrs is much less than 1/2 of the expected engine life. 90's Nautiques with fuel injection have overheat protection that helps insure that the boat has not been run hot. A compression test, or a leakdown test is always a good idea though.
Old    jbf            08-25-2003, 4:03 PM Reply
got a mc maristar from 94 with a lt1 engine.it has 1840 hours on it and still running perfectly.
high engine hours don,t mean the engine is bad.
