Old     (corbin)      Join Date: Jul 2009       07-15-2010, 4:06 PM Reply
so I'm in the process of changing out my bearing seal and it has this ring I'm told is called a "speedy seal". It took me a while to get the old one off and now that it is off I can't seem to get the new one on. Are they supposed to be this difficult to get on and off? the old ring and new ring are the same size which explains why it is being to difficult to get on. without the ring the seal doesn't fit.
Old     (polarbill)      Join Date: Jun 2003       07-15-2010, 4:13 PM Reply
Is that the seal or the race? The seal is probably a National Seal number 442251 if it uses the same as the 2 trailers I have changed seals on.
Old     (corbin)      Join Date: Jul 2009       07-15-2010, 5:53 PM Reply
neither. its a ring that the inner seal rides on. It slides onto the axle shaft and goes all the way to the back of the axle shaft. I'm guessing not too many folks have seen this??
Old     (h2ohangtime)      Join Date: Aug 2002       07-15-2010, 6:37 PM Reply
I just changed my entire hub assemblies and the seals were one-piece units that were pressure-fit into the back of the hub. Haven't seen a two-piece style like you're showing. However, I noticed that you're changing the axle with the brakes on it...I just changed my idler axle, so that may be the difference. Not sure...
Old     (ilikebeaverandboats)      Join Date: Jul 2007       07-15-2010, 7:03 PM Reply
Set them on the back of the hub, grab a flat piece of wood and a hammer, and gently persuade them into place
Old     (corbin)      Join Date: Jul 2009       07-15-2010, 7:54 PM Reply
The ring that is in my hand has to go on the axle and pretty much bottom out at the end. here are some more pictures that will hopefully help explain what I'm talking about. I already have the seal in the hub, now this part has to go on the axle stub. The last picture shows the ring as far back as I can get it but it needs to go all the way back... another 3/4 inch or so.
Old     (cwb4me)      Join Date: Apr 2010       07-15-2010, 8:06 PM Reply
find a piece of pipe or exhaust pipe about 2" to 3" longer than the axle get a block of wood on the end a drive it on with a hammer.
Old     (ilikebeaverandboats)      Join Date: Jul 2007       07-15-2010, 10:14 PM Reply
So the seal on the back of the hub rides up on the piece your holding? Still trying to figure this out. Mine isnt like that.
Old     (beryessaboarder)      Join Date: Apr 2005       07-15-2010, 10:31 PM Reply
A little heat on the wear ring will expand it and make it easier to put it on. Tap it on gently with a hammer or like Robert said find a piece of pipe to drive on. Or find a one peice seal and get rid of the wear ring all together.
Old     (trace)      Join Date: Feb 2002       07-16-2010, 5:20 AM Reply
That's called a Speedi-Sleeve. They're used for repairing grooved seal areas. Not sure why you need it if the area isn't damaged, unless it's just preventive. I agree - heat on the sleeve and a right-sized piece of pipe will get them on there no problem.
Old     (acurtis_ttu)      Join Date: May 2004       07-16-2010, 6:14 AM Reply
when I re-did my trailer bearings for the first time I was surprised at how much you have the beat the crap out of the components to get them back on, and taken apart.
