I’ve been out on business travel and I’ve had other obligations that I’ve had to spend time on. The problem, as Jeff pointed out, was the type of acrylic that I chose.
I did apply epoxy this afternoon. The results are again a mixed bag. I thought that I had read on Sway’s that if you were using epoxy resin then you didn’t need to put down a clear. That was wrong. The epoxy bled through the tape.
After the epoxy cures-hard I think I can clean the bleed through up with a razor blade. It will be a lot scratching but I think that’s where I’m going.
The whole Thing
I like how the design came out
The bleed through at the tape seams was predicable. This should be easy to clean up with a razor blade.
The big pin line seemed to bleed more than the nose art.
