Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through May 25, 2007
Old     (trash)      Join Date: Jul 2001       05-16-2007, 12:34 PM Reply
I'd like to put a fat sac in my rear locker. The locker is above the gas tank. How can I plumb it so as to prevent siphoning through the vent line and drain lines? The ports will be slightly below the top of the sac. I plan on using a Tsunami pump in the bilge to pump water into the bag, and another Tsunami pump attached to the bag for draining.
Thanks
Trash
Old     (maxx_wake)      Join Date: Sep 2003       05-16-2007, 12:42 PM Reply
Run the emty and vent lines to some point in the boat that is higher than the top of the sac and then run it back down to the thru hull from there.
Old     (trash)      Join Date: Jul 2001       05-16-2007, 12:59 PM Reply
I don't think that will work. If I fill my bag so that it's full (and water is coming out the vent line), then it will still siphon from the bag. There is no air in the line to break the siphon.
Trash
Old     (detonate69)      Join Date: Apr 2001       05-16-2007, 3:27 PM Reply
How about check valves.
