David, If I might make a suggestion...buy sacs instead of purchasing hard tanks. It may be same amount of money or cheaper, plus it'll give you the flexibility to add/remove water weight as needed. My X10 with hard tanks are OK, but once you start adding additional weight (above KGB), you'll soon find you need more weight in the rear than the hard tanks can give. I'll be ripping my hard tanks out this winter, but I'll hold onto them so I can go back to a stock setup.
