See above
"What could have happened is you let your batteries get down very low, still cranking on your system, that could fry an amp. An extra battery would have helped then, possibly, but most amps will shut down before they blow."
your amps will msot likely start to clip when they get in a low power situation. B/c jl amps have a regulated power supply (produce same output regardless of input) they will usually shut down if voltage is low, but as voltage drops amp draw dramtically increases (play with ohm's law formula). When you have really high current draw you will start generating excess heat. you could fry the power supply by starving it from power, but unlikely as the protection would have come on....we're talkign abtou high quality amps, but even they have lemons.
