Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through August 27, 2003 > Archive through May 13, 2004
Old     (brick)      Join Date: Nov 2003       05-07-2004, 2:18 PM Reply
I have a Mercruiser 350 MPI. I went to change the water-seperating fuel filter today and the service manual talks about activating a schader valve to relieve pressure in the fuel system prior to removing the filter. First, I can't find the schader valve! Does anyone know where the valve is or give me advice on changing the filter?
Thanks in advance,
Tim
Old     (boarditup)      Join Date: Jan 2004       05-07-2004, 3:42 PM Reply
A schraeder valve is on the hose. You have a quick connection hose.
I have a similar motor and have no problem with simply spinning off the filter. Just have a rag to wrap it up and collect the spilled fuel.
Old     (bill)      Join Date: Feb 2001       05-08-2004, 3:32 PM Reply
yea i didnt do any pressure valve either i just took it off with and oil filter remover and put the new one on hand tight..very easy job...
Old     (brick)      Join Date: Nov 2003       05-09-2004, 12:50 PM Reply
Thanks. This is the first time I've done the service. I was afraid that if I didn't release the pressure I would have fueling spilling.
