Old     (jonblarc7)      Join Date: Jul 2006       11-25-2013, 11:49 AM Reply
I just got a 07.5 duramax with 37" tire and maxed out 6" lift. I just sold the tire and now I'm going to run 35" and de-crank the lift to about a 4.5" lift and 3" blocks in the back. Do you think I could get away with a B&W 5" drop hitch.
http://www.ebay.com/itm/B-W-HITCHES-...34b42c&vxp=mtr
Old     (rugbyballa3)      Join Date: Feb 2013       11-25-2013, 12:03 PM Reply
yeah its a chevy the ride low to begin with. i know my f350 8" lift on 37s take a 10" and it still isnt enough
Old     (Fourspeednup)      Join Date: Apr 2010       11-25-2013, 2:15 PM Reply
I'd guess 6" drop would be the ticket but every trailer is different. Check out these Diversitech adjustable hitches. I took a close look at them a few weeks ago at SEMA. The self locking hitch is badass, no more pins and it's got anti rattle, spring loaded balls. I don't know about you but loose hitches drive me nuts.
http://www.etrailer.com/comparison.a...pc2=DTALBM6600
Old     (steveo142)      Join Date: Dec 2012       11-27-2013, 4:19 PM Reply
I have a 2004 duramax with a 6" RCD lift running 35's. To tow the boat level I use an 8" drop.
Old     (steveo142)      Join Date: Dec 2012       11-27-2013, 4:21 PM Reply
another
Old     (jamespjackson95)      Join Date: Jul 2012       11-27-2013, 4:57 PM Reply
I have a 2001 silverado, 6" suspension, 3" body with 35s. I only have a 6" drop and haven't had a problem in 3 years.
Sent from my iPhone using Tapatalk
Old     (Shawn)      Join Date: Aug 2011       11-27-2013, 6:27 PM Reply
Most standard trailers these days are designed to travel level when the ball is 18" off the ground to the top of the ball. Take a known drop hitch...say a 2"...put it on your truck, measure from the ground to the top of the ball, subtract 18" and that will tell you how much more of a drop you need.
I also factor in the drop in suspension when the weight of the boat is on the hitch to maintain that 18" height.
Old     (steveo142)      Join Date: Dec 2012       11-27-2013, 9:11 PM Reply
I was always told from the dealer, 19" to the top of the ball. So yeah, 18-19" should get you there...
Old     (phathom)      Join Date: Jun 2013       11-28-2013, 1:42 AM Reply
Measuring tape?
Old     (WheelerWake)      Join Date: Mar 2013       12-01-2013, 6:18 AM Reply
It's important to get the trailer level to allow the surge brakes to function correctly.
Old     (bass10after)      Join Date: Feb 2010       01-29-2014, 5:23 PM Reply
hey blair what drop did you end up going with on your hitch?... I need a hitch for now but want to be sure it will accommodate a lift down the road.
Old     (jonblarc7)      Join Date: Jul 2006       01-30-2014, 6:16 AM Reply
I went with the B&W drop hitch it adjustable 5" down and 5-1/2" rise. I love it and if you look around you can find it for about 165.00
