Take about 2/3 of your normal raley cut, and squat down more on your way in - concentrate more on popping up at the wake, and go for the grab IMMEDIATELY upon leaving the wake - once you get the grab, you can go for all the extension you want - these falls aren't nearly as bad as raley falls because your body is not extended, and you are in a more compact position, so don't be scared - just get er done Also, put more weight on your front foot than you think you should on the way in, this will help you keep the board level and hopefully prevent stargazing and chasing the grab
