After demoing an 05 X-2, i noticed that at wakesurfing speeds with the stock ballast filled, the wake only cleanly curled over on the right side (looking back from the boat). I know this has to do with the prop rotation, but can the left side of the wake be surfable?? Thanks
Okay, here is how we weight our boat for surfing. It is absolutely incredible! The following is for a regular wake. We only set it up once for goofy, but I'm pretty sure it was the same idea:
Port Stock tank Two Fly High Fat Sacks stacked on top of each other in port copartment. 10 bags of lead...some stacked on top of hard tank. The rest was put just forward of the fat sack underneath that little corner cushion. Two bags of lead up front, plus the belly 2/3 to full. We ride somewhere between 10.7 and 10.5.
Jesi, that sure seems like a lot of weight in the corner without much up front. I've noticed that when I ride like that, it VERY big, but not very long and we can only go back about 5 feet or so. When we put a few people up front (and fill the ski locker sack) it's not as big, but we're able to go back 10-15 feet. Do you find the same?
We usually don't have a lot of people on our boat for surfing...not very many people surf in our area. I think the most we've had in the boat with someone on the water is three. As of yet, we have not put more weight in the front.
I don't have the greatest depth perception, but I think that with our boat weighted the way we do, I can get back about 10-12 feet. Maybe not the whole 15. I'm going to look into that, though. I could definitely be interesting. Thanks.
ok cool... yeah, usually when we ride (04 X2) i fill the 750lb sack in the locker, fill the center sack, move about 200lbs of lead to whatever side we're surfing, and leave about 500lbs of lead in the bow. It's beautiful.
