Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through March 18, 2009
Old     (hype29)      Join Date: Feb 2007       02-25-2009, 5:47 PM Reply
I need some tips on removing window tint. I had the window regulator go out in my expedition and it took a big gash out of the tint. So I have to take the tint off and have someone retint it
Old     (cowwboy)      Join Date: Jul 2008       02-25-2009, 6:06 PM Reply
If you can rent a steamer that would be the best.
Old     (spherren)      Join Date: Aug 2005       02-25-2009, 7:07 PM Reply
just peel it off, then use a razor blade and glass cleaner to scrape the glue off. should take you ten min.
Old     (wakesetter101)      Join Date: Oct 2005       02-25-2009, 7:08 PM Reply
Get a razor blade and a can of Windex. Pull all the tint off once you get under it. Then spray the glue with windex and scrape it off. Easy to do.
Old     (toneus)      Join Date: Feb 2007       02-25-2009, 7:53 PM Reply
Spray white vinegar on the tint. Then place saran wrap on the vinegar to hold it on the tint. Let it sit for 15 minutes and peal.
I swear, it works, I've done it.
You will find this on Google too.
Old     (warwagon)      Join Date: Jan 2009       02-26-2009, 2:40 AM Reply
or you could just pay an extra 10 dollars when you have the window tint re-done and they'll do it for you
Old     (aarond0083)      Join Date: Apr 2007       02-26-2009, 7:05 AM Reply
Razor blade and Gunk glass cleaner. I just removed mine off my truck a few weeks ago to have it done darker.
Old     (detonate69)      Join Date: Apr 2001       02-26-2009, 8:34 AM Reply
Razor Blade and goof off cleaner. takes about 10 minutes.
