Here's how I learned it: Follow the wake coming at you only, don't even look at the boat wakes behind the boat. Pick a roller coming at you and follow it in all the way, you know the boat waves parallel to you will be there, so it's only important to track the one coming at you. You can't really look for a peak to hit because they form and move away so fast, it should max out right about when you hit it, so if it's not there when you are close, don't worry just concentrate on riding into that mess! Good luck
