At the present time I have a launch pad 440 lb. rectangular sac and 50 lbs. of lead on each side of the engine. Then we are running a full sac that gets to approximately 450 lbs and another small sac that gets to approximately 250 lbs. in the open bow. I am going to be installing an automatic system probably this winter. I have a custom sac on order right now that will completely fill the front ski locker which should hold about 750 lbs. I will probably then add another 100 lbs of lead to the front bow. After it's done I will have about 950 lbs. in back and 850 lbs. in front. I may use another small sac to place on the floor if I don't have very many people with me. Ideally you want about 900-1000 lbs. in back, 600-700 lbs. in the locker and 350 - 500 lbs. in the open bow for an unbelievable wake. Don't get me wrong, the way I have mine set up now with approximately 1600 lbs or so throws a very nice wake. I'm just saying if you want it like the pros, you need about 2000-2200 lbs in there with it fairly even from front to back. Hope this helps. Let me know if you have any other questions.
