Do NOT start the engine for 10-15 minutes once a month. You will cause condensation to form. Since you will shut down the engine before the condensation burns off, you will be leaving moisture in the innards of the engine. This is bad. Put a 1 amp trickle charger on a lamp timer to add an hour charge a few times a week. That'll take care of the battery. The remaining advise is sound.
