Yea, the PSS system is genius. It makes you wonder why anyone even bothers with other designs. If you don't know how it works, watch their little video. There are cases in large yachts where you can not have a straight shaft and you need a "no play" packing like the OJ solution, but in a wakeboat situation it only makes alignment more of an issue. I have seen 1 case in my life of a PSS leaking. It was due to a scratch in the Ceramic. The customer cleaned out the bottom of his boat the prior summer and and had major fiberglass repair and all new underwater gear. The shop that did the repair did not replace the PSS, but instead used the old one, which I believe they scratched and reinstalled. It caused a small spring leak that the customer had be fix a year later.
