Old    lakeside5_10            05-15-2008, 12:35 PM Reply
. a 12x48x72 2lb. block goes for 92 bux. i guess i will start hot wiring my own now.
www.hotwiredirect.com/eps-block-molders/
Old    surfdad            05-15-2008, 12:44 PM Reply
At 1" thick what is that 48 blanks? :-) You'll have to post up that huge block of foam. :-)
Old    lakeside5_10            05-15-2008, 12:47 PM Reply
sorry 12" thick
48" wide
72" long.
Old    surfdad            05-15-2008, 1:30 PM Reply
That's what I meant - you'll cut 1" thick rockers from it and probably net 48 blanks. You'll have boards coming out your ears! :-)
Old     (smedman)      Join Date: Feb 2006       05-15-2008, 3:31 PM Reply
Wow -- that is a great price!!
If you hotwire from a rocker template you will get much less than that...
But like Jeff says -- if you cut them one inch thick (flat) and bend the rocker you will have boards for days....
Old    lakeside5_10            05-16-2008, 5:37 AM Reply
i dont get yall's math
i see it as 24 blanks with stringer if cut at 1" and last blank would be thinner. this would be to glue the 12" wide sections together.
or 4 blanks cut at 3" thick blanks for a rocker template.
anyone use 3lb. eps foam ??
anyone doing artwork on their charity board.
Old    surfdad            05-16-2008, 5:55 AM Reply
It's all dependant upon the dimensions of your board Mark - if it's 1" t x 12" w x 24" l you can get over 100 out of that billet. :-) What are you're dim's?
I've used 3 pound on the rails - it's pretty stiff/dense. Overkill for the core, IMO.
No art on mine - just e.balsa and the logo's.
Old    lakeside5_10            05-16-2008, 7:18 AM Reply
brain fart on the 48" i was thinking of 24". yea thats alot of blanks.i think i will get it 12x24x72. I am trying to get some freehand artwork done this weekend and if i dont then the board will be painted light gray with a black stripe.
Old    surfdad            05-16-2008, 7:34 AM Reply
That'll look sweet! I can't wait to see it when it's finished up.
Old    lakeside5_10            05-16-2008, 9:30 AM Reply
Jeff ,
the hook up is on for the artwork, can anyone say tiki!!!!!!!
Old    surfdad            05-16-2008, 4:10 PM Reply
Cool!
