James, I have two Rule 2000 GPH aerator pumps lying on the garage floor right now. I took them out of my system and replaced them with two Simer pumps. I had been using a Rule 1100 and a Jabsco Macerator for draining, but they too are lying on the garage floor now. With two Simer pumps, I don't have to turn any valves to fill or drain, and my fill time is about the same as it was and my drain time is about 1/4 of what it was. 1100 pounds in about 5 minutes. Aerators are overrated in my opinion now. I ran 1 inch pvc in my system, so that does help with the fill/drain times. I also have 2 thru hulls. With the SPDT switch, and three relays for each pump, I just have to hit switch up to fill, and down to drain. Before I had to open the fill valve, fill it, then close the valve. Draining was easy, just hit the switch, but it was very slow (over 20 minutes). I like my current set up very much and is as close to automatic as I can get (I don't have any type of overfill drain system). I have to watch the bags when I am filling them to keep from over filling. Go with the Simers and stay away form the aerators. If it means anything, I paid $100 each for the Rule 2000s, and $57 each for the Simers.
