Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through August 01, 2004
Old    absolutofft            06-27-2004, 5:55 PM Reply
It looks just like it is faded with the sun but when you scratch it with your fingernail the black shows through again.
What type of cleaning fluid should I use to clean this stuff off?
Old    stevenf            06-27-2004, 7:36 PM Reply
it maybe pvc from your trailer guides that bump you into place. If that is it. use a dry towel and elbow grease rub in all directions then peel it off the towel. That was what was on mine. worked good.
Old     (typhoon)      Join Date: Jul 2001       06-27-2004, 7:41 PM Reply
I had that from the white writing on my trailer guides. I had to use goof off but be careful with the stuff.
Old     (denwakebdr)      Join Date: Apr 2004       06-27-2004, 11:42 PM Reply
hey aaron....I was told to use acetone on my white rub rails that had yellow.....cleaned them right up....not sure about black thou...good luck
Old     (rschrock)      Join Date: May 2004       06-28-2004, 7:22 AM Reply
I've always used steel wool with a very light hand. This is on black. It takes everything off and leaves the surface very smooth. This will also take off any scratches or light gouges.
