Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through November 17, 2003
Old     (talltigeguy)      Join Date: Sep 2003       10-16-2003, 5:42 PM Reply
I went with my friend this weekend on his 19' Bayliner Capri. I didn't expect a lot, but the wake was not too bad - on the right. The left however has this obnoxious roll on top. Is there anything he can do?
Old    upupnaway            10-16-2003, 6:51 PM Reply
Distribute some weight so it is evenly weighted on both sides. as long as your hull is uniform, the wake should be uniform as well. (unless it is caused by the prop rotation, then I can't help ya.)
Old    chrispy1            10-17-2003, 8:09 AM Reply
outboard or I/o?
Old     (trace)      Join Date: Feb 2002       10-17-2003, 10:27 AM Reply
move weight to the side that is rolling.
Old     (talltigeguy)      Join Date: Sep 2003       10-17-2003, 10:35 AM Reply
It's an I/O. I wondered if prop rotation has anything to do with it, but I've been in other I/O's without this problem. The one I'm most familiar with has a dual prop, however.
Old    kent            10-17-2003, 4:02 PM Reply
its going to be alot harder to clean it up on an i/o, the hull will have alot to do with it, some hulls have the leg inset a bit more and there is more fiberglass towards the prop which makes it easier to clean up. dual prop will churn it up even more, but still try adding weight to that side. We deal chapparal boats, ive managed to clean it up on some models for some people, some have not. Mostly I try to get them in a Tige`!
Old     (talltigeguy)      Join Date: Sep 2003       10-17-2003, 5:39 PM Reply
You are a very intelligent person, Kent. My friend has a lot more spare cash than me, but my boat is a lot better.
Old    kent            10-17-2003, 8:03 PM Reply
haha same sort of situation here, although i have no spare cash now.
Old     (wesgardner)      Join Date: Oct 2003       10-27-2003, 6:28 PM Reply
I have a similar problem in my 2150. The boat is quite sensitive to weight side-to-side and can easily make the wake asymmetrical. I recently built a pylon for $75 - very strong. Here's a pic. I have one sac but need more...
WEs
Pylon
