Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through March 19, 2004
Old    murrayair            02-10-2004, 12:56 PM Reply
I saw this in Overtons catalouge this month. It looks similar to TAPS or the Wedge, it's a hydrolic plate on the back of the boat that produces a bigger/more shapely wake by raising or lowering the plate. Anyone have any experience with it? If it works I want to install one on my Nauti 2001.
Old    wolfpack            02-10-2004, 1:13 PM Reply
Bennett trim tabs have been used for a long time to help with bigger boats, evening out rides, and quicker planing.
Old    wolfpack            02-10-2004, 1:32 PM Reply
Will not make a wake bigger, will only help with shape. There is no substitute for sinking a boat lower in the water. This is one reason why a san wake can get so large... 1000 lbs of ballast makes more of a difference in a narrow boat than a boat of equal length that is a foot wider.
Old     (fogey)      Join Date: Mar 2002       02-10-2004, 1:55 PM Reply
It is just like the TAPS plate, and the hydraulic wakeplates offered on Supras, Moombas, and a few others (Centurions? Ski Supremes?). I have one on my Supra, and here's the deal:
1. It will not make a wake bigger.
2. It can be used to make it smaller, and to clean it up a little in some cases.
3. It can help a boat with very heavy ballast get on plane faster.
4. It's great for adjusting the ride. It absolutely will stop porpoising, and the ride is much smoother in choppy water.
BTW, you start out by saying that it "looks similar to TAPS or the Wedge." A TAPS plate doesn't look anything like a Wedge. They're totally different in design, purpose, and operation.
Old    maverick_gear            02-10-2004, 6:10 PM Reply
TAPS is a fancy Tige word for bennet tab, everything jeff says is accurate.
Old     (greatdane)      Join Date: Feb 2001       02-10-2004, 10:34 PM Reply
Actually, TAPS from TIGE is the combination of a trim tab on a hookless hull. Their boats are tuned to plane on their tails and the wake plate is to allow the boat to plane at higher speeds without porpoising.
Old     (aneal000)      Join Date: Feb 2002       02-11-2004, 9:02 AM Reply
I heard a good one the other day... a guy called the TAPS system the: Tige Anti Porpise System
Old     (wakehype)      Join Date: Dec 2002       02-11-2004, 10:34 AM Reply
Someone call my name???
Old     (fogey)      Join Date: Mar 2002       02-11-2004, 12:18 PM Reply
Yes, Tige claims that the TAPS "system" includes the plate and certain features of the hull design. But, as I said, the "TAPS plate" itself is exactly like a Bennett trim tab (except that a TAPS2 plate is electrically actuated instead of using hydraulic pressure).
Old    murrayair            02-15-2004, 1:41 PM Reply
So would you guys say it is worth $415? Seems a little steep to me if all it does is make the wake a little cleaner and help the boat plane a little faster.
Old     (fogey)      Join Date: Mar 2002       02-15-2004, 1:53 PM Reply
I paid about $700 for the factory option, and I'd gladly do it again. However, if you're talking about a direct drive boat, I'm not sure it will make as much of a difference as it does with a V-drive.
Old     (pierce_bronkite)      Join Date: Jul 2003       02-15-2004, 6:09 PM Reply
You have to remember the TAPS on the Tigé's are designed with the hull shape in mind. Your boat may not respond well to adding a trim tab. Just take in to consideration the shape of your hull.
Old    banks            02-17-2004, 9:33 PM Reply
ok look taps is yes a trim tab but no it doesn't work the same as it would with other boats.
Tige has a convex hull, curves up on both ends like a wakeboard.
- without it the boat is going to porpus up and down.
- with it boat won't porpus and you get added benifits the back naturaly falls into the water because the convex hull stays convex with taps in the up position.
- also lets you fine tune how much of the back of the boat is in the water, helps if you weight the boat
- lets you change the angle of the boat while going so you have a smoother ride on the water
- since the back all ready falls the nose of the boat is way up in the air the only way to really understand it is to get in one and use it yourself
- if you put it on another boat, like supra does, all you could do would be make the front go further down into the water.
- finaly if it weren't different Tige wouldn't need a patent for it, and they do have one.
(Message edited by banks on February 17, 2004)
Old     (luchog)      Join Date: Jun 2002       02-18-2004, 6:53 AM Reply
i have always heard of them as the bennet flaps, any pics on this anyway?
Old    banks            02-18-2004, 7:59 AM Reply
http://www.tige.com/tige2003/performance-versatility/taps.htm
click it
Old    banks            02-18-2004, 8:00 AM Reply
and
http://www.tige.com/tige2003/performance-versatility/convexvhull.htm
and
http://www.tige.com/tige2003/performance-versatility/combinedversatility.htm
Old     (supraman)      Join Date: Jan 2002       02-18-2004, 10:23 AM Reply
"if you put it on another boat, like supra does, all you could do would be make the front go further down into the water."
Actually, B, the tab on the Supra does all these things:
- with it boat won't porpoise
- helps with holeshot when you have extreme weight in the boat
- using the plate changes the attitude of the wake - while it can't make it bigger, it shapes it and can make it more rampy and less abrupt if you so desire (as many newbies do - it lets you keep the boat loaded with weight while making the wake less extreme)
(Message edited by supraman on February 18, 2004)
Old    banks            02-18-2004, 10:25 AM Reply
you still don't get it.
like i said the only way your gonna get it is to use it. a friend of mine has a supra. there's a big difference b/t the two. the back of the supra goes down because of weight not because of the hull design.
Old    banks            02-18-2004, 10:28 AM Reply
if you want to understand it reasearch tige' and how it works, then drive one and test it out in every way. sorry if my last post was insulting
Old     (supraman)      Join Date: Jan 2002       02-18-2004, 10:37 AM Reply
b -
I didn't say "Supra and tige are the same." I didn't even say that "TAPS is not unique." The interaction of a wake plate and hull design is what makes TAPS, according to tige. The fact is, I've been on a tige and tested it and I DO get it.
Both the Supra and tige have trim tabs. They are mechanically almost identical. They serve the same purpose - to modify the running attitude of the boat. The tige has a different hull design, so the effect of the trim tab is different on the boat. tige calls that TAPS. Period.
The plate on the Supra still does all the stuff I said it does just a couple posts earlier. That was my only point. Get it?
Old    banks            02-18-2004, 10:40 AM Reply
"so the effect of the trim tab is different on the boat"
thanks
