Old     (ylewc)      Join Date: Oct 2009       02-17-2010, 7:51 AM Reply
Thoughts and opinions? What's the wake like?
Old     (dh03r6)      Join Date: Mar 2007       02-17-2010, 8:03 AM Reply
I would guess small, you would most likely need more weight then you would feel comfortable with to get a good wake.
Old     (texasmoombav)      Join Date: May 2009       02-17-2010, 8:16 AM Reply
I had a 2000 Moomba Outback. The wake is small, and the boat sits very low. If you add any ballast you will definitly take waves over the bow. Not a bad starter boat but there are probably better options.
Old     (ylewc)      Join Date: Oct 2009       02-17-2010, 8:20 AM Reply
Thanks, Just from the looks of the boat it looks to put off a small wake, and sit very low in the water. Just trying to get some other opinions in hopes that it was an illusion as it is a good deal.
Old     (behindtheboat)      Join Date: Aug 2006       02-17-2010, 8:51 AM Reply
I think "small" is relative to what it is being compared too. Small compared to a V-drive, 23ft boat, etc, Of course. Small compared to more comparable boats, it does the job.
Old     (pickle311)      Join Date: Oct 2005       02-17-2010, 12:46 PM Reply
I had the 05 Outback, same basic hull design I believe. The wake was small when compared to a big v-drive, but it was a decent wake ecpecially for us as beginners. For weight, I had 300lbs in the front and the 750lb sack under the rear seat. It worked pretty well, but you really had to keep a close eye on rollers. The bow would dip very easily.
Old     (jeff_mn)      Join Date: Jul 2009       02-17-2010, 2:30 PM Reply
Same. Should have 1200-1500 lbs in mine this summer. Aside from watching the nose - it's a respectable wake. Doesn't matter if it's a d-drive or v-drive. It's about the hull design and the amount of weight.
Good starter boat. We like ours.
