Old     (loudsubz)      Join Date: Aug 2001       04-12-2008, 8:51 AM Reply
I have a Launch Pad Sofa and need to buy a ballast pump for it. Is the Launch Pad Uber pump worth it, or is it really problematic? I have read that it leaks and breaks quite easily.
I was looking for just the adapter to connect to the bag so I could fill it up with another pump but a couple people I talked to said I had to buy a Uber Pump cause its the only one that will fit with the connector. Is this true? If not where can I buy the connectors.
Old     (lovin_the_wake)      Join Date: Jul 2007       04-12-2008, 9:03 AM Reply
go with the tsunami pump its much better
Old     (pureblue)      Join Date: Jun 2002       04-12-2008, 9:21 AM Reply
Are the tsunami aerator pumps like these http://cgi.ebay.com/ebaymotors/Attwood-Tsunami-Cartridge-Style-Aerator-Pump-1200-GPH_W0QQcmdZViewItemQQcategoryZ26449QQihZ005QQitem Z150233962062QQrdZ1QQsspagenameZWDVW, the same as the version that usually sells for $100 and is designated for sac filling?
(Message edited by PureBlue on April 12, 2008)
Old     (lovin_the_wake)      Join Date: Jul 2007       04-12-2008, 9:27 AM Reply
yup pretty much
Old     (loudsubz)      Join Date: Aug 2001       04-12-2008, 9:29 AM Reply
if I go with the tsunami pump what fitting will work on the bag I have?
Old     (lovin_the_wake)      Join Date: Jul 2007       04-12-2008, 9:34 AM Reply
well I'm not 100% sure which fitting to use you might contact buywake.com and ask them
Old     (loudsubz)      Join Date: Aug 2001       04-12-2008, 9:38 AM Reply
Thats the thing, I sent them an email and they said there wasn't a fitting I could buy and that I had to buy the Uber Pump from Launch Pad instead.
Old     (lovin_the_wake)      Join Date: Jul 2007       04-12-2008, 9:40 AM Reply
well you can buy a Tsunami pump like the one on the link to e-bay above clamp a hose on and then buy http://www.buywake.com/catalog/detail/kb75Z and make your own . . . I think
Old     (lovin_the_wake)      Join Date: Jul 2007       04-12-2008, 9:42 AM Reply
i know i've seen a post before where someone did this same thing it was either on here or on wakeboarder.com
(Message edited by lovin_the_wake on April 12, 2008)
Old     (loudsubz)      Join Date: Aug 2001       04-12-2008, 9:44 AM Reply
I was hoping I could do something like that, but wasn't sure why buywake said I could not.
Old     (lovin_the_wake)      Join Date: Jul 2007       04-12-2008, 9:46 AM Reply
hmmm good point
Old     (pureblue)      Join Date: Jun 2002       04-12-2008, 7:54 PM Reply
Ya that replacement kit looks like it would work. It is kind of a rigged job since you are buying the hose and putting on a different pump. They probably would rather you dish out for a whole pump system than $4 bucks for an adapter.
