This will work... push the radio all the way in. Then pull up the tabs on the metal bracket that held the radio in place (the metal bracket that is still in the dash) Remove this bracket, pull the radio out the opening. On each side of the radio their are little metal tabs, make sure they are at 90 deg angles, or pointing staight out. Otherwise when you put it all back together the radio might slide back in too far. You will have to unplug all of the RCA's, wire harness and antenna and reinstall the bracket first, then slide the stereo in from the front. As far as why it quit working? Did it just completely go dead? No lights or anything, or no sound, or it locked up... more details please. I assume you checked the circuit breakers under the radio/throttle...
