Old                07-08-2003, 8:45 PM Reply
which should i learn first? i am scared of a whirly cause i dont know if i can get the handle slack enough to rotate over my head. how hard is it. should i learn that or a tantrum to blind? thanx
Old     (truk)      Join Date: Feb 2003       07-20-2003, 5:12 AM Reply
try the wirly bird on the trampoline first. The trick to a good whirly is to get a nice lofty tantrum wake to wake, there should not too much tension on the line. after you leave the wake throw the arm with the rope around your head. put your chin on the shoulder facing away from the boat. you should spot the water almost as soon as you start spinning.
Tantrum to blind is easy if you can land blind.
Good Luck.
