I have a rule 2000 as my drain pump for 1 sack! It is the stock fill pump for your XLV. You can upgrade to a Rule 3800 if you want to fill faster. You should look at the current requirements and fuse size if you go through all this. As for drain pumps, it's an easy swap but you'll have to go from 3/4" hose to 1" to use the 1100. I see you are in Marietta, do you ride at Alatoona or Lanier? I'm on the north end of Lanier most of the time.
