PP wasn't performing as well as I thought it should, alot of wondering and slow adjustments. After inspecting the engine and going through the troubleshooting I noted that there was no return spring on the idle. so i jerry rigged one on there and have to say that it made a huge difference, when I overshot getting someone up, it dropped right down to the setting and held it there PERFECT. anyways, as i said now it is jerry rigged and would like to see a pic or two of a better way to put a return spring in, as of now it is up and over stuff so it is not very clean. also should there have been a return spring on there from the factory?
