I did it because the corner was dragging and causing a double lip on my surf wave. You should do it if you think it will help. Guess I should have called it a modification rather then a rebuild. Tools used were a skill saw, band saw, hand planer and a router. Oh yea I also sanded with a palm sander with 150 grit. looks better then new also! I recommend doing the sanding and re-oiling even if you don’t cut it down.
