Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through September 22, 2008
Old     (mrboston187)      Join Date: Jul 2008       09-04-2008, 2:55 PM Reply
is it very difficult to tighten the hinge up on these? The right one seems a smidge looser than the left, and i was gonna tighten it up, is it that difficult? should i take it to the shop or what
Old     (pri3st)      Join Date: Aug 2007       09-04-2008, 3:04 PM Reply
No it's very simple, look at it & you'll figure it out.
(Message edited by pri3st on September 04, 2008)
Old     (extremeisaac)      Join Date: Aug 2005       09-04-2008, 3:16 PM Reply
Kiley, on the cable part where it attaches to the binding on the bottom there is an eyelet hole held in with a screw, remove the screw and you will see that you can thread in and out the eyelet hole. clockwise makes it tighter counter makes it looser
Old     (mc_x15)      Join Date: Jul 2008       09-05-2008, 5:23 AM Reply
I have torques that are doing the same thing. It doesnt seem like its the hindge though, seems more like the top part with laces are stretching. When i got them the laces would pull tight, now the left one pulls all the way tight but the binding is still slightly loose. Can I replace the top par with the laces?
Old    sealyon.net            09-05-2008, 5:58 AM Reply
On the 08 boots the cable adjusts on the bottom not like the 07 being on the side.
Just take the boot off the board and there are 2 cables with nuts on the bottom. that is where you adjust them.
It only takes a little.
Old     (jarrod)      Join Date: May 2003       09-05-2008, 7:21 AM Reply
Yep, Lyon has it.
Rob, your local pro shop should have extra strings and lace locks. I believe the torque still uses the older laces/locks. See if you can get a set of the 08-up stuff for your torques. It works very well.
Old     (mc_x15)      Join Date: Jul 2008       09-05-2008, 7:48 AM Reply
will do thanks jarrod
Old     (mike2001)      Join Date: Feb 2008       09-05-2008, 7:49 AM Reply
Rob, contact CWB for replacement laces and locks. They sent replacments to me, no questions asked. Good customer service.
Old     (mc_x15)      Join Date: Jul 2008       09-05-2008, 9:57 AM Reply
really, i will do that, thanks mike k, appreciate it
