Joseph, Are both amplifiers shutting on and off simultaneously while the source unit remains on? I'm a little surprised that the voltage threshold is identical for two dissimilar amplifiers. I thought a Red Top is specifically a starting battery. You may want to remedy this with a deep cycle replacement. Deep cycling a Red Top can significantly lower its ability to accept a charge and shorten its useable lifespan. And yes, you should have a dual-bank, minimum 10 amp smart charger. Failure to fully recharge a battery will cause a premature reduction in capacity. David Earmark Marine
