This is easy: * Export using compressor * when the Batch window comes up, pull doen the present menu * choose MPEG-4 NTSC Source Material, then MPEG-4 Improved NTSC Large Progressive * you can then choose the same but small progressive. compressor will make 2 versions at once, I guarantee that this will work - I've done it lots of times!
