10-16-2007, 8:45 AM
10-16-2007, 9:09 AM
what lake is that?
10-16-2007, 9:19 AM
Mead and Havi....the last two weekends
10-16-2007, 9:20 AM
sweet wake
10-16-2007, 9:21 AM
thanks
10-16-2007, 10:28 AM
Here is a TIGE' 24V with six people and 800 Lbs. Ballast. Same place and same time as G-Money.
10-16-2007, 10:45 AM
Nice curl......
10-16-2007, 11:52 AM
Super clean wake. Very nice!
10-16-2007, 12:06 PM
do you have any photos of the wake from the other side? I have an rz4 that i bought from matt. I'm in Vegas as well. i'm pretty sure the 24v is the same hull as the rz4 so i'd like to try and weight it the same.
10-16-2007, 12:17 PM
A couple more pics from an awesome weekend. Asemaster Moki from a distance
10-16-2007, 12:37 PM
jamesmjennings You should have come to the Cold Water... We could have helped you dial in your surf wake.... (Message edited by gmoney27 on October 16, 2007)
10-16-2007, 12:43 PM
jamesmjennings Here's the darkside of the 24V about a board length and a half back using only a 1400# custom surf sac in the rear storage
10-16-2007, 6:34 PM
give some input on this wake please srry cant get it to load will try again / popjpeg{511901,Upload} (Message edited by lav on October 16, 2007) (Message edited by lav on October 16, 2007)
10-16-2007, 6:45 PM
try again
10-17-2007, 8:53 AM
What boat/speed/ballast???? Just by looking quickly you need more ballast up front to lengthen you wake to get a bigger sweet-spot. .02
10-17-2007, 1:40 PM
thanks g money this is what i am looking for this set up is 02 xstar 750 in rear,550 on floor 550 on seat, 200 brick in observor 400 in ski locker 200 on bow seat and whatever you can get in intergrated bow sack my guess is 400 and boat speed is 11.5mph Think i should move one of the 550 to bow floor or add another sac? thanks again all input is welcome.
10-17-2007, 1:44 PM
also have read that it helps to weight darkside a little to sink whole boat but still listing port, when surfing reg,in 205v hull any experience with this?
10-17-2007, 2:32 PM
Thats 3050# Try taking some of the weight out from the center of the boat and try just using the weight in the locker, seat and bow. That should give you a nice clean wake at a slower speed (9.5-10.5) witch is better to surf. 11.5 is a little fast for surfing...IMO I bet with 3050# the wakeboarding wake is HUGE Good luck and just keep playing with it..
10-17-2007, 2:43 PM
thanks i will try that out and yes it is very big when boarding will also try and get pics
10-18-2007, 9:24 AM
i planned on going to the tige event and even confirmed with matt but my daughters' soccer game got changed. we are planning on going out this saturday. the wake is dialed in pretty nice but the pocket is a little close to the swim step. i would like to be a bit further back in the wake.
10-18-2007, 6:48 PM
jamesmjennings (jamesmjennings) on Thursday, October 18, 2007 - 9:24 am: i planned on going to the tige event and even confirmed with matt but my daughters' soccer game got changed. we are planning on going out this saturday. the wake is dialed in pretty nice but the pocket is a little close to the swim step. i would like to be a bit further back in the wake. What speed are you running James. I was amazed to find that 24V needed to be about 11.2 for the wake to shape up while I can surf my 22Ve at 10mph and the pocket lengthens as I increase speed. Ours is still a work in progress tho Post some pics when you can.
10-19-2007, 9:11 AM
i'm running at 10 mph. i'm able to freeride with little or no weight in the boat and taps set all the way up. i'm going to load up some weight this weekend and work on it. i'm able to ride the 5'6 lf ventura with no problem but it's like riding a garage door. i have a 4'9 hl broadcast that i can ride but i have to pump it a lot and work the wake to keep going, both are fun.
10-24-2007, 12:15 PM
Nice wake G-money, nice long pocket. Here's a pic of LovinPowell from the Tige Reunion with my Tige 23V with 1000 lbs in back and 650 up front.
10-25-2007, 9:40 AM
That wake looks good, how far back are you from the swim deck?
10-29-2007, 3:39 PM
Sorry for the slow response. About 8 feet
11-02-2007, 6:27 PM
most recent blurry but 13.5mph enzo 216
11-06-2007, 8:54 AM
Here is my son at Bear Lake. 1000 lbs in back, 600 lbs up front. 2 people in the boat at about 10 mph:
