Old     (rake)      Join Date: Jun 2003       05-26-2006, 8:38 AM Reply
Looking at getting a 2001 PS 205V and would need to add Perfect Pass. I was wondering if it was a hook to paddle wheel or drill job for that year boat.
Thanks in advance. Search did not yield any definitive results.
Old     (jarrod)      Join Date: May 2003       05-26-2006, 8:42 AM Reply
2005
Old     (jarrod)      Join Date: May 2003       05-26-2006, 8:44 AM Reply
You'll be drilling a hole. In 05 they added throttle by wire with a paddle wheel speedo for their own speed control system.
The good news is that PP works great on that boat. Once you get the hole drilled, installation is a breeze.
Old     (rake)      Join Date: Jun 2003       05-26-2006, 8:44 AM Reply
Thanks J-Rod. I'll put a stop at home depot for a hole saw bit on the to-do list.
Old     (jarrod)      Join Date: May 2003       05-26-2006, 9:08 AM Reply
There have been a lot of great posts on this.
Useful tips....
drill a pilot hole first. I purchase a 12" long 1/4" bit for the pilot hole. Then I scored by hand using the hole saw. Then I taped the hell out of both sides to minimize chipping.
I'm sure you thought of this, but you might look at the PP install on an early Xstar or late x2 (2004) to see where the unit was installed. Location effects PP performance and MC had it dialed with that boat. Good luck
Old     (mjmurphy53711)      Join Date: Mar 2004       05-26-2006, 9:28 AM Reply
another piece of advice, make sure the paddle wheel is located in a spot where a. it is always in the water (on plane or not) and b. isnt going to get broken off by bumps on your lift or trailer!
Old     (djhuff)      Join Date: Mar 2005       05-26-2006, 10:48 AM Reply
Paddle wheel went further back that '05
My old X30 had a paddle wheel and it was an '03. Dont know how much further back they were standard though, you'r probably looking at a drill job.
Old     (jarrod)      Join Date: May 2003       05-26-2006, 11:10 AM Reply
Hmm.... really?
Did your X30 have Perfect Pass?
Old     (antbug)      Join Date: Jul 2004       05-26-2006, 11:14 AM Reply
Gordon ~ Are you selling the SN 2001?
Old     (bigjessup)      Join Date: May 2002       05-26-2006, 12:04 PM Reply
Our 02' X-Star came standard with the paddle wheel, but it also came with PP from the factory.
Old     (fbroen)      Join Date: Apr 2002       05-26-2006, 1:15 PM Reply
Our '03 X2 has paddle wheel speedo standard.
Pitot tubes weren't on any models that year I don't think. I think that was true in '02 as well.
Old     (rake)      Join Date: Jun 2003       05-26-2006, 1:15 PM Reply
Thanks for the information guys. I'll check a few x-stars/x-2's to verify the right placement.
Ant - Yes, I'll be selling the Silver when this all goes through. It's a great boat, I just need some more room.
Old     (jarrod)      Join Date: May 2003       05-26-2006, 1:36 PM Reply
Guys, your 02-03 Mastercrafts.....
Was the paddle wheel the Perfect Pass paddle wheel?????????
Or was the paddle wheel for the actual Mastercraft speedo?
Old     (fbroen)      Join Date: Apr 2002       05-26-2006, 1:52 PM Reply
For speedo and PP pickup -- one paddle wheel for both.
Old     (antbug)      Join Date: Jul 2004       05-29-2006, 8:22 PM Reply
Gordan ~ What are you selling her for?
Old     (djhuff)      Join Date: Mar 2005       05-30-2006, 10:07 AM Reply
I did not originally have PP, but when I installed it, I just had to plug in to that paddle wheel when I took out the speedo.
To answer your question, MC used the paddle wheel for all speed information (PP or not) at least as far back as '03
Old     (jarrod)      Join Date: May 2003       05-30-2006, 10:20 AM Reply
Got it. Thank you Matt.
Old     (tlb)      Join Date: Feb 2003       05-30-2006, 10:35 AM Reply
I had an '02 x-7 that had the wheel and no PP.
I think that was the first year with the wheel even if you had no PP.
Old     (hjziegler)      Join Date: Feb 2006       05-30-2006, 1:48 PM Reply
I saw a picture of present X-2 and it has vents / a stepped hull. Where is the wheel located on this model?
Old    x10            05-31-2006, 10:07 PM Reply
Our 2002 had the paddle wheel and it was the first year.
Old     (djhuff)      Join Date: Mar 2005       06-05-2006, 6:40 AM Reply
Hans, the wheel is located near the center drain plug, ahead of the vents (bad location).
Old    debsxstar            06-05-2006, 5:42 PM Reply
Yeah my 02 xstar has the paddle wheel and PP. I believe this was the first year. MC actaully had difficulty getting my PP to work correctly. It was related to the cable getting wet or something.
