Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through November 14, 2005
Old     (sangerlover)      Join Date: Sep 2005       10-29-2005, 1:22 PM Reply
Anybody have any luck using wheelchair batteries for the 2nd battery ? Guy at work said they are a little less expensive and last longer than most deep cycles . On line for about $100.00 .
Old     (chas)      Join Date: Feb 2002       10-29-2005, 1:41 PM Reply
we use the MK Power Cells and they seem to work out very well. I would recomend running all the same batteries for even charge and discharge rate.
Old     (rodmcinnis)      Join Date: Sep 2002       11-03-2005, 1:05 PM Reply
The best bang for the buck are the "T-105" size golf cart batteries. It takes two, wired in series but they give you the most amp-hours per dollar of anything else I have found.
Old     (acurtis_ttu)      Join Date: May 2004       11-03-2005, 1:36 PM Reply
Rod, can the t-105's start a motor? or do they not have enough cranking amps?
Old     (rodmcinnis)      Join Date: Sep 2002       11-04-2005, 1:22 PM Reply
Yes, they would start the boat no problem.
