Lights draw a lot of current. If you do not have a good connection, then you get resistance at the connection. Resistance is bad and will result in heating. Just because the connections are gold, does not mean you have proper crimp/ torque on the connections. If you had to cut strands of wire to get them to fit in the connector, that can cause issues. How many wires are feeding the negative lead? Where are the fuses located in the wiring? Need more install input.
