Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through June 07, 2004
Old    rainrider            05-28-2004, 3:12 AM Reply
i wakeboard behind a eruo f3 and a pretty good at jumping the wake. I need more AIR!!! What are some suggestions to get more air so I can start doing some tricks. 180, no problem, Its time for a backflip. I need to know how to launch
Old    walt            05-28-2004, 7:24 AM Reply
Have You added any weight to the boat ?
Old     (craiger)      Join Date: May 2002       05-28-2004, 7:27 AM Reply
Work on your edging technique. Once it is solid, then you just need to edge harder.
And you won't find any tips for a "backflip", but you will for a tantrum.. look around on this site for trick tips..
Old     (jarrod)      Join Date: May 2003       05-28-2004, 7:34 AM Reply
Add a thousand pounds to tha floor; add 5 feet to your rope; pull slightly faster (maybe); then do what rammer said.
Old    shanny            05-28-2004, 9:49 AM Reply
goto: www.wakeboarder.com they have tons of trick tips and stuff its great
Old     (flashalexb)      Join Date: May 2004       05-28-2004, 1:42 PM Reply
Maybe a board that has more pop that will lauch you up instead of out.
