Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through June 07, 2004
Old     (lyle)      Join Date: May 2004       05-22-2004, 9:03 AM Reply
I am wondering if anyone has any ideas on how to keep my wake from rolling over so quick, it washes out about 52 ft. thanks
Old    zanek            05-22-2004, 10:41 AM Reply
More weight in the boat should help. Or, going a tad bit faster or slower may change things. But for sure adding weight should help via: fat sacs. My boat used to wash out at about 60 or 65 feet so we added fat sacs to the front of the boat (I don't like an abrupt wake) and now our wake is giant and only turns over probb at 80 feet
Old     (lyle)      Join Date: May 2004       05-23-2004, 6:45 AM Reply
how much faster, and how much weight do you have??
Old     (guido)      Join Date: Jul 2002       05-23-2004, 11:05 AM Reply
What kind of boat?
Old     (kevin_bird)      Join Date: Dec 2002       05-23-2004, 3:06 PM Reply
normally more weight in front helps but is it a 14 ft bayliner or something else ya know some boats just dont have great wake shapes
Old     (jklein)      Join Date: May 2001       05-24-2004, 9:20 AM Reply
make sure the weight is even on both sides of the boat too. I noticed I had a little wash out, and moved a guy to the other side of the back seat, it cleaned up instantly.
Old     (lyle)      Join Date: May 2004       05-24-2004, 11:14 AM Reply
My boat is a 1989 18.5 ft vip. I think that it has alot of potential, just have to get the wake right.
Old     (guido)      Join Date: Jul 2002       05-24-2004, 2:14 PM Reply
On a Direct drive or V-drive we generally ride anywhere from 22-25 mph at 75-85 feet of rope (usually with quite a bit of weight..maybe 2k plus lbs). Your boat is a bit shorter and I'm guessing an I/O. It may not make that great of a wake that far back, but if you keep the weight even and the speed in the 22-23 range and add weight to the bow it should be OK. I don't know what kind of weight you are running, but I'd try a 500 sac filled all the way up in the front walkway for starters and go from there. It should help the boat plane out faster, too.
Old     (lyle)      Join Date: May 2004       05-26-2004, 5:10 AM Reply
thanks, any other ideas,
Old     (bill)      Join Date: Feb 2001       05-26-2004, 4:03 PM Reply
james just throw a 600lb sack in the bow area or soemwhere up front...then use the trim on the motor to find the sweet spot..also if you have people on board have them move around the boat once your up to speed and see the wake ..whichever side is foaming up have the person move toward that side until it cleans up and then stay there..
good luck
Old    lfultrarider131            05-27-2004, 6:55 PM Reply
go faster that'll do it or try turned a little bit left or right
